Topic: Problems with Pioneer DJM900NXS2 Magvel Crossfader problems
I'm having a serious issue with my cross fader in my DJM 900 NXS2. When playing a song on deck 2, (left deck) with the cross fader all the way to the right I still have sound from the left deck, the same think happens when reversed i.e. music on deck 3 right deck and cross fader all the way to the right. What's also happening on the left side of the cross fader about an inch from totally closed the right deck kills then all the way to the left the right deck comes back on. The A side and B side selector on the mixer are in the in the appropriate position to work in this configuration. Here's a YouTube video of my issue.
https://youtu.be/X4xFnLNXWiA
Posted Sun 23 Oct 16 @ 8:05 am
There are 4 options to check. I had a similar issue with audio and video acting on "wrong" fader and crossfader...
I'm using mixer as audiocard, so this is for when using as audiocard:
1: Within VDJ: Set the audio settings to match your players and faders
2: i have all the hardware buttons and knobs on the mixer on default position (including fader curve per channel etc)
3: make sure your VDJ mapping corresponds with your hardware
4: start with default VDJ skin. there could be a skin issue or not compatible skin, so try it out with the VDJ skin first and try different skin settings like changing the mixer order
These 4 points gave me a good working mixer including the crossfader.
You can read more about this in two topics about the 900nxs2 I started before:
http://virtualdj.com/forums/213373/General_Discussion/Mixer_faders_acting_on_videofiles_question.html
http://virtualdj.com/forums/212473/Hardware_Technical_Support/Pioneer_DJM-900NXS2_support.html
Posted Wed 02 Nov 16 @ 9:52 am
EDIT: I assumed you use it with VDJ :)
Posted Wed 02 Nov 16 @ 9:54 am
