Im having an issue with settings resetting to default in VDJ
Examples
Every restart requires me to log in
Not able to load my own samples in sampler
eq settings in softwear reset to default at start up
Eq plug in does not save eq profiles
Examples
Posted Wed 14 Sep 16 @ 6:29 am
This sounds like a file access permission issue.
Check your "Documents\VirtualDj" folder access writes and make sure you have write access to it and all it's subfolders.
On a typical Windows installation the following users and groups should have full access:
1) Authenticated Users
2) SYSTEM
3) Administrators
4) YourUsername
Beside these entries you should also see "Users" with read rights only. That's normal.
However if your account on Windows is a "simple user" instead of "Administrator" you should log in as Administrator and change the access rights for "Users" group to allow writes as well.
2) SYSTEM
3) Administrators
4) YourUsername
Posted Wed 14 Sep 16 @ 7:25 am
ok i will try this and let u know if issues are resolved
Posted Wed 14 Sep 16 @ 1:10 pm
I checked those settings and they are all set for full access...the resetting to default settings is still happening
Posted Wed 14 Sep 16 @ 5:23 pm
just the other day someone told you to run plugin installs as and administrator and you said that fixed your problem have you since switched to using an administrator account?
Posted Wed 14 Sep 16 @ 7:24 pm
the softwear build updated to new build and started having issues...ive reverted back to an earlier build 2857 and now testing to see if things are functioning normally
Posted Wed 14 Sep 16 @ 8:34 pm
problem still continued...installed build 3409,
opened vdj as administrator still not saving adjusted settings within VDJ,
still cant load new sample banks,
EQ plug in profile does not save,
VDJ folder security is set to open access for all users.
Posted Thu 15 Sep 16 @ 12:39 am
did two more re installs of VDJ and every thing is working now
Posted Thu 15 Sep 16 @ 4:44 am
