i want to apply post fader echo after i fade out the song in one of the chanels
Posted Sat 06 Aug 16 @ 9:47 pm
What build are you using?
Posted Sat 06 Aug 16 @ 10:02 pm
Anywho you want the latest 'early access release' 3343
and do as the picture shows
Posted Sat 06 Aug 16 @ 10:25 pm
I got 3324
Posted Sun 07 Aug 16 @ 1:33 am
Posted Sun 07 Aug 16 @ 1:36 am
ok thanks for the information I let you know if work
Posted Sun 07 Aug 16 @ 1:41 am
loco dog thanks for the tip works just like I want.
I play with vdj and serato with this feature vdj is actualy much better.thanks again.
Posted Sun 07 Aug 16 @ 1:49 am
I'm intrigued. Can you explain pre and post? What are the benefits of both?
Posted Tue 23 Aug 16 @ 12:54 am
I like the idea of fade echo but I changed the setting to post and can't get that effect.
Posted Tue 23 Aug 16 @ 1:12 am
what hw
Posted Tue 23 Aug 16 @ 4:35 am
Post Fader Effects work only with Master & Headphones audio setups.
If you use "External Mixer" audio setup then they won't work.
Posted Tue 23 Aug 16 @ 10:42 am
