Topic: Buzzing and popping and no sound with 2FX
AsTheDJPRO InfinityMember since 2008
Buzzing and popping and no sound with 2FX Flanger has buzzing and Filter cuts off when move it after turning on then off,got restarted VDj---8.2 3268/1166
Mac 10.9.5
2.6 Ghz IC i7
8GB 1600
Posted Mon 20 Jun 16 @ 5:46 pm
Posted Tue 21 Jun 16 @ 3:21 pm
The Flanger FX still not working,the filter fix in 3278
Posted Fri 24 Jun 16 @ 1:32 pm
AdionPRO InfinityCTOMember since 2006
Your flanger High-pass value seems to be incorrect.
Try to move the slider and see if the value gets back to the normal range. Then possibly a restart of virtualdj will be required to get it working again.
Posted Fri 24 Jun 16 @ 2:00 pm
That not it when I get home I will do a 2nd video were there no back ground sound at work,now it just buzzing when on..
Posted Fri 24 Jun 16 @ 3:18 pm
https://youtu.be/_gi3XA_gCiA
Posted Fri 24 Jun 16 @ 3:44 pm
With the bug in the latest update it's a bit hard to see what the highpass knob is set to.
You can try to go to Documents\VirtualDJ\Plugins and remove native_Flanger.ini to see if that fixes it.
Posted Fri 24 Jun 16 @ 4:06 pm
Yes that fix it maybe from 3202 or 3205+ when it started doing that.Thank You
Posted Fri 24 Jun 16 @ 4:46 pm
