So with videoForceFullScreen = 0 or -1, useDXVA = yes, skinFPS and videoFPS set to 30, you get a low refresh rate on the output?
Could you hold your mouse over the cpu meter to bring up the tooltip, and check the video fps there?
Posted Wed 08 Jun 16 @ 11:00 am
I did 2 test to see the diference with the fps.
One with the suggestions you made:
Skin: 20 fps
Video: 20 fps
Now one with: videoForceFullscreen= 1 and the rest the same
Skin: 33 fps
Video: 33 fps
Adion, It is a big diference, because if I want to higher the skin and video framerate, I get even higher fps (skin max 30 fps and video 60 fps).This is with videoForceFullscreen = 1. If videoForceFullscreen = 0 or -1 it sticks at max. 20 for both.
Skin: 20 fps
Video: 20 fps
Skin: 33 fps
Video: 33 fps
Posted Wed 08 Jun 16 @ 11:59 am
Thanks for the tests.
Drivers are up to date right?
(I would have expected more from an i3-4300, as I even get good results with a Atom X5-Z8300 and videoForceFullscreen on 0)
Posted Wed 08 Jun 16 @ 1:05 pm
You're welcome ! It is even a Intel® Core™ i5-6200U Processor (2,3 GHz, 1866MHz, 3MB cache) with an HD graphics 520 and 8 GB. So the machine is fast enough I think.
Posted Wed 08 Jun 16 @ 2:07 pm
The drivers are up-to-date with the latest 4444
Posted Wed 08 Jun 16 @ 2:08 pm
I see now 2 other posts with the same error. I hope there will be a fix, I now went back to 8.1. This is working for now....
Posted Fri 10 Jun 16 @ 4:55 am
Same thing on mine. AMD a8, Radeon graphics. Now video etc works fine as long as I don't choose anything
Posted Fri 10 Jun 16 @ 5:30 am
Exacly if i just play the video's there is nothing wrong, but don't choose the settings button ;-)
Posted Fri 10 Jun 16 @ 7:59 am
@ Adion can you tell me when this is fixed ? Because only than can I try the newest version again. Otherwise I have a instable instance of VDJ.
Posted Mon 13 Jun 16 @ 4:50 am
I now see more tickets that adressed this bug: http://www.virtualdj.com/forums/210339/VirtualDJ_8_2_Technical_Support/External_Video_Output_Issues.html
Posted Thu 16 Jun 16 @ 9:13 am
Posted Thu 16 Jun 16 @ 11:01 am
I guess this won't be fixed ??? 8.2 is out now, but with the same issue.... I very disappointed..
Posted Wed 06 Jul 16 @ 10:22 am
We are working on a fix.
Posted Wed 06 Jul 16 @ 11:59 am
@ Adion, I am very happy to hear that you are working on a fix ! Thank you !!!
Posted Wed 06 Jul 16 @ 6:11 pm
@ Adion, you are a hero !!! Thank you for fixing my problem ! I works like a charm.
Posted Wed 13 Jul 16 @ 5:01 pm
