Forum: VirtualDJ 8.1 Technical Support
Topic: Virtual DJ Remote issue
Okay, so I'm using VDJ 8. I connect to the remote on my Ipad No problem, everything works great. Love the new vdj8 skin.
Then, suddenly, the skin changes to vdj 7 skin on the ipad, and doesn't work. I have to reconnect. This happens after about 2 minutes every time.
Posted Tue 24 May 16 @ 4:12 pm
SBDJPRO Infinity Member since 2006
Strange that one.
Do you have the "look for old v7 remotes" box checked in the remote config screen in VDJ?
Posted Tue 24 May 16 @ 5:19 pm
SBDJ wrote :
Strange that one.
I just looked and noticed that the answer is yes. I just unchecked it and tried things out and it seems to working just fine. Thanks!!
Posted Tue 24 May 16 @ 5:50 pm
