Okay, so I'm using VDJ 8. I connect to the remote on my Ipad No problem, everything works great. Love the new vdj8 skin.
Then, suddenly, the skin changes to vdj 7 skin on the ipad, and doesn't work. I have to reconnect. This happens after about 2 minutes every time.
Posted Tue 24 May 16 @ 4:12 pm
Strange that one.
Do you have the "look for old v7 remotes" box checked in the remote config screen in VDJ?
Posted Tue 24 May 16 @ 5:19 pm
SBDJ wrote :
Strange that one.
I just looked and noticed that the answer is yes. I just unchecked it and tried things out and it seems to working just fine. Thanks!!
Posted Tue 24 May 16 @ 5:50 pm
