Gang -
Some MP3s visit the RED in the limiter and certain tracks sound distorted. M4A files sound very nice...
Anyhoo, what is the formula to adjust the gain in options?
Posted Mon 23 May 16 @ 12:05 am
ewitles wrote :
Gang -
I would recommend turning the auto gain function on in options menu. Once you turn that on I would set the "zeroDB" option to -3db. I use these settings and have no issue with my tracks!
Let me know if you still have questions!
Posted Mon 23 May 16 @ 2:02 am
Is that in db or %?
Posted Mon 23 May 16 @ 2:05 am
ewitles wrote :
Is that in db or %?
That would be in db.
Posted Mon 23 May 16 @ 2:06 am
Ok, I did that. Does that mean I need to rescan?
I did that and did a rescan. Please see the attached. Guess it was a year + since I redid my database scanning.
A rescan appears to show a discrepancy. :(
Posted Mon 23 May 16 @ 2:12 am
Yes, you might have to rescan your tracks in order to apply the new settings to them... Are you running VDJ 8?
Posted Mon 23 May 16 @ 2:14 am
Latest (2 month old) 8.1.... Would love to know when any new versions are gonna drop.
Posted Mon 23 May 16 @ 2:52 am
Actually, the zeroDB value is a modifier for the gain value set bei the option "autoGain".
So you have to set autoGain to "auto".
Posted Mon 23 May 16 @ 12:18 pm
And rescanning is not needed when changing either option, just reloading the tracks in the decks is enough.
Posted Mon 23 May 16 @ 5:48 pm
