hey guys
i have virutal dj
and i love it
however its just missing
something. and that something
is an external play source.
e.g a mixer. how can i setup my
virtual dj to run with an external
mixer (e.g) wiht the sounds and
stuff being controller by the EQs
and CROSSFADER
that was possible wiht virtual dj
wasnt it? i just need to know how
to hook it up!!
cheers
i have virutal dj
and i love it
and CROSSFADER
to hook it up!!
cheers
Posted Sun 12 Oct 03 @ 8:32 am
Yes you can.
You need to connect your external source to the line-in input of your sound card.
Then, you can mix and display this input in VDJ. Look in the file explorer of VDJ, you can find "Sound Card". Clic on it and drag the driver you want (displayed in the right) on a deck.
That's all :)
Good Mix.
That's all :)
Good Mix.
Posted Sun 12 Oct 03 @ 11:49 am
the4 thing is.
i dont want to use turntables
i just want to control the mix
via an external mixer, rather then
use a mouse.
can this be done?
use a mouse.
can this be done?
Posted Mon 13 Oct 03 @ 12:01 am
just search the forums, there is a way to do that. you need 2 soundcards
Posted Mon 13 Oct 03 @ 12:06 am
... or one 3D card...
Posted Mon 13 Oct 03 @ 7:29 am
That's right, with 2 sound cards (differents one avoid compatibilities problem) or one 3D card (4.1 or 5.1) you can set (in Audio setup) mixer or headphone configuration.
With mixer configuration, each deck of VDJ will output through a different sound card output (front and rear).
So you just have to plug these two output to different input of your external mixer, like you could do with a dual cd player.
I hope this is the answer you were waiting for.
Good Mix :)
Good Mix :)
Posted Mon 13 Oct 03 @ 8:52 am
thyanks so much
im off to buy a mixer
any tips for which would
be best for working with
virtual dj?? (like is it worth
bpm counters nad stuff)
or wont that work
or wont that work
Posted Mon 13 Oct 03 @ 3:50 pm
Check out name brands like American Audio, or Numark. I've had very good luck with their products over the years. I've had several Gemini products as well, but wasn't very happy with the quality.
Good luck man!
Good luck man!
Posted Mon 13 Oct 03 @ 5:34 pm
i was thinking of going for a
pioneer CDM-300.
is that good, or a little too
advanced for Virtual DJ??
will the bpm counter and
stuff work with virtual dj
ro what???
pioneer CDM-300.
ro what???
Posted Tue 14 Oct 03 @ 12:00 am
There is no "too advanced" Get what you can afford.
The bpm counter on a mixer will attempt to count a beat from whatever input source you have plugged it. I Have a Numark 1835X with an onboard counter. It does a fine job counting the BPM. However, it's kind of a waste, since VDJ counts it's own beats.
Posted Tue 14 Oct 03 @ 3:35 pm
