the SOUND INSURGENT wrote :
A few changes I would like is to have the mixer controls removed and the master preview window made bigger.
I will check what I can do. I don't plan to remove the mixer controls from this view, but perhpas a new view. Also keep in mind it's the width that's the main factor for the preview size...
Then where the eq's for decks 3&4 are have the timecode controls/options placed there.
You mean like this ? :P
If you enable TC inputs on your sound setup then TC controls appear on mixer.
Also can we get the code to map a button to scroll threw the panels please??
cycle '@$SilSl_Center' 10
Posted Tue 07 Jun 16 @ 6:19 pm
The time code options like mode, config, clone deck, etc.
I understand your thoughts on leaving the mixer controls there but with an external mixer they aren't necessary ;-)
And yeah I don't mind if the preview window is stretched because it is just a preview.
Posted Tue 07 Jun 16 @ 6:55 pm
And that's why I lean towards creating another view rather than removing the volume controls from this one! :)
Posted Tue 07 Jun 16 @ 8:21 pm
Perfect for the View/Panel button on the upper left part of my SX2 and SZ
Posted Tue 07 Jun 16 @ 8:48 pm
Nice!!!
Posted Tue 07 Jun 16 @ 9:48 pm
Will something like this do the job for you ?
I have not finished the layout yet...
Posted Tue 07 Jun 16 @ 10:46 pm
Man thats PERFECT!!!
Posted Tue 07 Jun 16 @ 11:12 pm
George the Genius - amazing stuff and so good with 8.2.
Posted Thu 09 Jun 16 @ 10:29 am
Version 3.3 is out!
Changelog:
2016-06-09 v3.3
Added new central panel "Scratch Video" on 4 Decks Swap view.
Changelog:
2016-06-09 v3.3
Posted Thu 09 Jun 16 @ 10:59 am
Awesome!! And Thanks a million!
Posted Thu 09 Jun 16 @ 12:17 pm
How or where do I click to select and active deck ? I can't find it.
Thanks for the hard work on the skin Phantom.
Posted Thu 09 Jun 16 @ 4:08 pm
On deck screens bottom right corner there's a "Master" button. This sets the masterdeck.
Posted Thu 09 Jun 16 @ 4:11 pm
Whats the script to change between video and audio display for the SilverSleek#3 on a keyboard. I use to uses var_equal '@$SilSl2_Center' 1 ? set '@$SilSl2_Center' 2 : set '@$SilSl2_Center' 1 for SilverSleek#2
Posted Sat 11 Jun 16 @ 7:52 pm
When mind. I figure it out...
var_equal '@$SilSl_Center' 4 ? set '@$SilSl_Center' 2 : set '@$SilSl_Center' 4
Posted Sat 11 Jun 16 @ 7:59 pm
V3 is only showing 1 effect drop down using my Pioneer DDJ-SB2. It does not allow me to select an alternate controller. V2 shows 3 effect drop downs and knobs for each effect.
Can I have my 3 effects back please.
Posted Sat 11 Jun 16 @ 8:20 pm
Press the "M" (Multi) button on each FX section
Posted Sat 11 Jun 16 @ 11:29 pm
Posted Tue 14 Jun 16 @ 1:45 pm
Can't size up the images George ....... "Sorry, the link you have used is not valid anymore."
EDIT: Seems to be working now.
Posted Tue 14 Jun 16 @ 1:46 pm
I still cannot get 3 effects at once on v3. I have had to roll back to v2.
Any ideas???
EDIT: Nevermind I just figured it out by clicking on the 'm' next to effects.
EDIT2: None of my volume faders move on v3. My controller is a Pioneer DDJ-SB2.
Any ideas???
Posted Wed 15 Jun 16 @ 9:17 pm
Yeah that's what he told you, lmao!!
Posted Wed 15 Jun 16 @ 9:21 pm
