hi guys im using a giga port sound card sometimes the one side goes of i have to exit vdj then set back up ive tried two cards the same issue i am a full member any ideas
Posted Mon 14 Mar 16 @ 5:42 pm
When this happens instead of exiting VDJ go to CONFIG->AUDIO tab and click apply to reset the sound engine. Does this fix the disconnect?
Posted Mon 14 Mar 16 @ 6:55 pm
tried that still the same the vu meters are running it only corrects its self when restart the program this happens when the deck is paused for a bit !!
Posted Tue 15 Mar 16 @ 1:42 pm
