Hello,
For the noavation Launchpad Mk2 i want to script the leds in two pages. Here my script :
<map value="RGB_PAD_8_1" action="var '$PAGE' 0 ? sampler 1 play ? blink 300ms ? constant '129,255,129' : constant '0,128,0' : constant '0,20,0' : constant '129,255,129' : var '$PAGE' 1 ? deck 1 loaded ? blink 200ms ? constant '255,255,70' : constant '255,255,150' : constant '0,20,0' : constant '0,20,0' " />
RGB_PAD_8_1 is the name of the led.
constant 'xxx,xxx,xxx' is a color
If I want to see the page 0, if I start the sampler 1, the led blink correctly and all the other leds are correct.
But if I select the page 1, I have some colors of the page 0 and I don't know why ?!
Can you help me ?
Can you help me ?
Posted Sat 05 Mar 16 @ 9:38 pm
<map value="RGB_PAD_8_1" action="var_equal '$PAGE' 0 ? sampler 1 play ? blink 300ms ? constant '129,255,129' : constant '0,128,0' : constant '0,20,0' : var_equal '$PAGE' 1 ? deck 1 loaded ? blink 200ms ? constant '255,255,70' : constant '255,255,150' : constant '0,20,0' : var_equal '$PAGE' 2 ?..." />
Posted Wed 09 Mar 16 @ 10:59 am
First mistake was that you need to compare the value.
Hence instead of var you need to use var_equal
Second mistake was that you instruct your queries to show an "extra" color:
Your structure:
If page=0
__ if sampler 1 play
____if led blinks state on
______color 1
______(else led blink state off)
____color 2
____(else sampler 1 does not play)
__color 3
__(else page is not 0)
color 4
Anything after this point never evaluates true since your last statement (set color) evaluates true when page is not 0
Correct structure is:
If page=0
______color 1
____color 2
__color 3
if page=1
page=1 can evaluate true in this case since it's executed on the page is not 0 step of previous code block. :)
Your structure:
If page=0
______color 1
____color 2
__color 3
color 4
If page=0
______color 1
____color 2
__color 3
if page=1
Posted Wed 09 Mar 16 @ 11:11 am
I forgot to thank you. Thank you, it works great !!
Posted Sun 03 Apr 16 @ 8:44 am
