not ready yet:)
    Posted Fri 10 Oct 03 @ 10:10 pm
          Mine is ready :-)
http://members.xoom.virgilio.it/coyotedj/
Screen saver VDJ v3
Thanks Dimitris for helps to find a this server :-)
Coyote
Screen saver VDJ v3
Coyote
Posted Fri 10 Oct 03 @ 10:22 pm
          to download the screen saver that i made go there
http://members.xoom.virgilio.it/dimitrist/virtualdj/
AND ATTENTION!!!!
Before you download each file to your pc rename it to RAR file. For example if you downloading the first file when you press save it will be appear to be saved with that name "Virtualdj screen saver.part01" BEFORE you click ok rename it to "Virtualdj screen saver.part01.rar"
after you d/l ALL the files renamed double click in ANY of that and drag and drop in your computer the folder.After all of that ...ouf! you can enjoy!
AND ATTENTION!!!!
Posted Sat 11 Oct 03 @ 12:15 am
          actually you click on the 1st one to extract:)
    Posted Sat 11 Oct 03 @ 12:43 pm
          Has anyone else been working on or created a new screen saver since 2003?
MS
    MS
Posted Fri 05 Aug 05 @ 12:54 am
