So I had to get a new computer and I used to use the Virtual DJ that came with my install disc. (V6.1.2) and I really liked that version. Now when I try to run it, its forcing me to upgrade if I want to set up my settings for my sound system. I use the RCA that was built into my controller. On the version I was forced to upgrade to (The 7) then I can set up my settings but nothing is working. I checked to see if there is a driver that I have to download, and I am not finding one. I feel like this should be a really simple fix but I dont know what to do. I even tried running it with 8 but nothing is coming through my speakers. Everything was just working fine and dandy with the 6 version, and I dont get why it all changed when I had to upgrade to 7
(excuse me if I sound stupid, I sometimes cant explain things really well)
Posted Mon 08 Feb 16 @ 2:39 am
can you please post a screenshot of your audio tab/ config perhaps.
usually you setup the Mixtrack as Master & Headphones for output
and then just click on the Mixtrack icon under cards ....
Posted Mon 08 Feb 16 @ 2:03 pm
