Hello,
I have a Problem with my new AKAI AMX Controller. In the native device mapping for this controller the Panel-LED (red) on the Controller is not in the list. Because of this the LED is not to use in the controller mapping. The Touch-LED (blue) is mapped in the device mapping and also to use in the controller mapping.
Is it possible to integrate this LED in the native device mapping? The LED had the same Midi-Note as the Button. So it is only a little problem to add it.
Thank you.
Best regards from Germany, Kevin
Thank you.
Posted Tue 26 Jan 16 @ 7:51 am
Will be fixed shortly.
Posted Tue 26 Jan 16 @ 4:23 pm
Thank you for the fast fixing!
Today I got a Update and the LED is now able to map!
Best support!
Thank you
Best support!
Thank you
Posted Fri 05 Feb 16 @ 6:18 pm
