Forum: VirtualDJ 8.1 Technical Support
Topic: Build 2770-1092 Crackling Sound
osuarezPRO InfinityMember since 2010
I just applied this build and now the sound is coming out all crackling. First question where can I get a previous version to this one?
Posted Tue 12 Jan 16 @ 2:37 am
FYI, I am back on 2587, found the link and crackling is gone.
Posted Tue 12 Jan 16 @ 2:58 am
eriedjPRO InfinityMember since 2011
In my sound config, I was getting all kinds of static bursts. I set my sound config with my MC6000MK2 to be MASTER - Denon DJ for ASIO Controller Ch 01 & 02 and HEADPHONES Denon DJ for Asio Controller Ch 03 & 04. I DELETED both line in 1 and line in 2 as part of the sound config. The static disappeared.
Using build 2770.1092 and now, no issues.
Check out George's Windows 10 tweaks on the official Virtual DJ Facebook Group. The tweaks are amazing!
Posted Wed 13 Jan 16 @ 8:56 pm
notice the crackling sound too....
Posted Thu 14 Jan 16 @ 3:50 am
Thanks for that, so basically delete my sound settings and start from fresh?
Posted Fri 15 Jan 16 @ 8:42 pm
ewitlesPRO InfinityMember since 2006
I have found it always helps to backup the settings file then rename it and have a new one made. That seems to cure many of the gremlins that pop up.
Posted Fri 15 Jan 16 @ 11:48 pm
