i have just bought an iMac and have downloaded virtual djay 8 and the app will not accept my key code as i have it registered to my iPhone 5.Can anyone tell me how to use key code on iMac now?
i have already tried deleting VDjay 8 from iPhone but still will not accept key code on iMac and is saying it is already registered.
Posted Sat 09 Jan 16 @ 8:15 pm
There is no such thing as a "key code" for VDJ 8. The registration works via a login system, once your purchase is linked to your forum account.
You need to add your purchase details (email etc) to your forum account, so that VDJ 8 knows who you are.
Posted Sat 09 Jan 16 @ 8:25 pm
its a LE Code i have not bought the pro version but on lap top sorry not iPhone was able to record remixes without the 10 min limit.
Posted Sat 09 Jan 16 @ 8:33 pm
Ah, so you're using a controller. You didn't mention that!
Did you buy this controller new? If not, then it's likely the previous owner already registered the VDJ LE that came with it.
Eh? Are you saying you've solved the problem?
Quote :
Posted Sat 09 Jan 16 @ 9:00 pm
no i bought controller.The LE Keycode worked on my mac but on iMac it is saying it is registered to another user ...me lol.on macbook.
Posted Sat 09 Jan 16 @ 9:07 pm
I think the LE only allows one controller per license
check here:
http://www.virtualdj.com/products/virtualdj/comparison.html
check here:
Posted Sat 09 Jan 16 @ 10:11 pm
yep theres the answer.not good but i'll have to use my macbook again now but thank you and other member for quick response.
Posted Sat 09 Jan 16 @ 10:38 pm
