Forum: Old versions
Topic: Help ME!!!
Help ME!!! How do I transfer a playlist i created in Virtual DJ to my external hard drive? Not the file codes, but the actual music.
Posted Sun 20 Dec 15 @ 4:42 pm
i am going to assume you are using vdj8 since it says you are a subscriber
right click the playlist and select "Export to" and select where you want it to go ......music files and a database and the playlist will all be sent to the place you select.
