Forum: VirtualDJ 8.1 Technical Support
Topic: Popping sound
After this last update there are loud pops coming from my music. I can confirm this because there are no pops when using cds in my decks.
2 denon 3700s
x1600 mixer
windows 10 vdj 8.1
Posted Sun 20 Dec 15 @ 7:07 am
blckjckPRO InfinityMember since 2008
Sounds like an issue with latency.
Are you using ASIO drivers?
Try renaming your settings.xml to see if there are different settings that you need with the current build.
Posted Mon 21 Dec 15 @ 2:33 pm
