Discussion about DN-HC4500 PRO FOREVER
Posted Wed 25 Nov 15 @ 1:30 am
Muy agradable!
Posted Wed 25 Nov 15 @ 6:08 am
Muchas Gracias, señor Zanard
Saludos
Rubén
Saludos
Rubén
Posted Wed 25 Nov 15 @ 11:16 am
bien el trabajo Exelente .. saludos
Posted Fri 04 Dec 15 @ 4:24 am
thx ;)
Posted Fri 04 Dec 15 @ 5:36 pm
Hello, as you switch to video?
Posted Mon 07 Dec 15 @ 9:22 pm
Sorry! I already got it
Posted Mon 07 Dec 15 @ 9:54 pm
Hi I glad you solved! have fun :)
Posted Mon 21 Dec 15 @ 8:12 pm
thx ;)
Posted Tue 26 Apr 16 @ 1:33 pm
GRACIAS X EL SKIN MUY BUENO
Posted Wed 27 Jul 16 @ 3:10 am
I have big Problems. :-(
Please someone can help me?
I can read nothing in browser.
Look my Screenshot.
Look my Screenshot.
Posted Mon 26 Dec 16 @ 1:58 am
Excellent job! Thank you!!!!!
Posted Thu 09 Mar 17 @ 12:58 am
the newest update has disabled the ability to make the font really huge. I know nothing about editing the skin. can anyone help?
yes I still use this skin and love it
Posted Fri 20 Sep 19 @ 10:28 pm
If you're referring to the two font adjustment buttons in the browser (which has nothing to do with this thread) being replaced with a single button, it's possible to change back to the previous buttons via the config settings. Just search for 'font'...
Posted Fri 20 Sep 19 @ 10:37 pm
Would love to know 2 things... 1) how to the split the waveform the way the pics show... left and right, or on top of each other... and 2) how to change the uppler left clock so on start up it shows 12 hr frame, vs 24 hr it is set for... thanks, Joe
Posted Sat 02 May 20 @ 1:52 am
1) Pick the view from the menu in the skin (to the left of the beat counter).
2) Set the option for 12hr clock from VDJ config.
Posted Sat 02 May 20 @ 10:45 am
thanks groovinDJ... must have changed when I updated from 7 to 8 a while ago... I knew I had done the waveform before but couldn't find it. I still can't find the clock one... you mean under "set up" ? Or else, where is Virtual DJ options? I've gone through set up a number of times and cant find it...
Posted Sat 02 May 20 @ 6:41 pm
