Topic: Support Pioneer XDJ-700 (Done) - Page: 3
Can i ask what is the pioneer site? For download xdj 700 driver?.. Thank you!..
Does the Displays from the XDJ 700 Work with VDJ 8.2 ?
Can we See in the Displays the Waveforms and other Informations from VDJ 8 we by the 2000 Nexus 2 Modells.
Greatings and Thanks
Dirk
The display works, yes.
But NO you can't see the scratch waveforms as with CDJ2000NXS2.
It's not supported by the device firmware
But you do see the (small) overall waveform on the bottom of the screen. It's however not usable for seeing beats, breaks or detail wave info. It's also only in blue colors and not RGB colored with the XDJ700
Ok Thanks for the Information over the Displays from the XDJ 700 with VDJ 8
Nice where when someone can Post a picture from the Display by the Work with VDJ 8 that i can better See this What you mean.
Thanks and Greetings,Dirk
vlnjacki wrote :
"......Nice where when someone can Post a picture from the Display by the Work with VDJ 8 that i can better See this What you mean"
In this topic: http://www.virtualdj.com/forums/221725/General_Discussion/Multiscreen_Support_for_VDJ_.html
I posted a picture with 2 XDJ700 players with VDJ8.2 playing on them.
You see in the bottom of the screen the waveform. That's it. No Big Waveform in the middle of the screen (only available with Pioneer Rekordbox or with a Rekordbox USB stick)
Ok Thanks i look There.
Someone have ask in German Forum for this than i have the ask here in the Topic for this XDJ 700.
But the XDJ 700 look greatings for Me, eventually i will buy 2x of they for me by End of this Year.
Greatings and Thanks Dirk
The XDJ-700 works perfect with and without VDJ. So you will not regret buying them.
Ok thanks for all the Infos her
Greatings ,Dirk
Hi,
is the needlesearch function on the touchscreen for VDJ available?
Greatz Nico
NicoRC wrote :
Hi,
Greatz Nico
Yes!
