I'm sure this has been asked for a hundred times now ......
The ability to right click any folder / playlist / history file / filter folder etc. and have the ability to export.
PDF > The folder with the information available in your browser view.
CSV/XLS > All database info which can then be filtered as necessary.
Users can then use this for karaoke lists, database of their music for prospective clients or for situations where you have to provide a list of played music for licencing.
Please, no plugins. This should be part of the main .exe for everyone to use easily. BPM Studio had this simple function to export to XLS back in 2000 ......
Thank you.
Thank you.
Posted Mon 23 Nov 15 @ 11:37 am
Any feedback on this?
If it's a definite no just say so.
Posted Tue 26 Jan 16 @ 3:04 pm
Your request is noted :)
Posted Tue 26 Jan 16 @ 4:16 pm
So what does that actually mean Scott. Is it on the development list?
Please, I can't handle the smileys. It was bad enough with Rune doing it all the time and now we have two :)
Posted Tue 26 Jan 16 @ 8:21 pm
You used one, so that's three! I'm sure we can look into adding something along these lines, but you know we never usually say for definite if/when something will appear.
Posted Tue 26 Jan 16 @ 9:49 pm
kradcliffe wrote :
Please, no plugins.
Please, no plugins.
Why not a Plugin ? Is it part of a regular live performance ?
Posted Wed 27 Jan 16 @ 12:51 am
Easily and intuitively being able to export list data to a user friendly
format is a Very Good Idea. And, yes, this has been asked before
in various different ways. I asked for this last year with no response
from Staff, so the idea is now, at least, getting their attention.
Posted Fri 29 Jan 16 @ 6:47 pm
I would really like to have this option added to VitualDJ.
Posted Thu 09 Jun 16 @ 8:16 pm
It's in version 8.2
You can export any view (playlist/folder/history/etc) to CSV or HTML instantly. Click the button and select "export browser view"
Posted Thu 09 Jun 16 @ 8:23 pm
its been added to Vdj8.2
-Export browser view to CSV or HTML
Posted Thu 09 Jun 16 @ 8:28 pm
This is the HTML view. Pretty good. thanks Scott!
Posted Thu 09 Jun 16 @ 8:30 pm
Posted Thu 09 Jun 16 @ 8:35 pm
How did you get this view Keith?? Im on a Mac and can only get a .cvs version.
Posted Fri 10 Jun 16 @ 3:17 am
Not sure how Mac works but in Win when you get the save dialogue you can click down on file type and select either csv or html.
Posted Fri 10 Jun 16 @ 8:11 am
Yeah I not getting the HMLT option, must be a Mac thing. Thanks for the time bro.
Posted Fri 10 Jun 16 @ 12:00 pm
Is there a way to show the time a song was played?
Or can it be implemented on a future update?
Posted Fri 10 Jun 16 @ 12:42 pm
Just add "last play" as a browser column and it will show. The play time at the end of history folders isn't included by default.
Posted Fri 10 Jun 16 @ 12:46 pm
As above - the browser export will export exactly what you see in your browser using the visible columns and the sort order. This means you can export all sorts of information - folder, playlist, history, karaoke history, ask the dj, search results, pretty much anything!
Posted Fri 10 Jun 16 @ 3:34 pm
Got it thanks
Posted Sat 11 Jun 16 @ 4:49 pm
Nice, however say you have 1000 songs in your playlist but you need a selected few by using this export browser view. How would you do that? I tried to move some songs to sidelist and bring this sidelist to view and hope this few would be sent as a excel file but just the original 1000 songs are sent again.
Posted Tue 21 Jun 16 @ 1:18 pm
