Hello,
The light on the buttons don't seem to light up with Virtual DJ 8. Is this an issue or how the controller works? Thank you.
Posted Thu 19 Nov 15 @ 11:09 pm
Power cycle the unit.
SYSTEM->Midi Controller->Midi Channel. Make sure its on Channel 1
Posted Thu 19 Nov 15 @ 11:32 pm
Just checked. It's on channel 1, but no lights turning on.
Posted Fri 20 Nov 15 @ 12:12 am
Not sure. I even updated mine to the latest Firmware 5.0 and still all LEDs are working fine.
If none of the LEDs are working for you, can you try with a different USB port, USB cable and maybe a different computer to double-check ?
Posted Fri 20 Nov 15 @ 12:45 am
I have the latest firmware too... Tried all the above besides trying it on another computer. All I have is this Mac to use this on. Are you on a Mac? Thank you for your help.
Posted Fri 20 Nov 15 @ 12:56 am
Didnt try on the Mac. Yes, you are right . LEDs dont work on Mac here either. Will investigate further , email Stanton and will let u know.
Btw, since the unit doesnt work in VDJ7 either, my guess is that there is compatibility issue with the new Mac OS.. I am running 10..11 here btw.
Posted Fri 20 Nov 15 @ 8:23 am
Sure. I hope it gets worked out soon.
Posted Fri 20 Nov 15 @ 12:28 pm
Any update on this? I'm on El Capitan too...
Posted Tue 24 Nov 15 @ 1:16 am
I'm guessing this product will no longer be supported... The sad part is I bought this a few weeks ago at best buy... Why is it selling when they stopped support? http://www.bestbuy.com/site/stanton-digital-dj-mixstation-black/2630982.p?id=1218341071261&skuId=2630982
Posted Fri 11 Dec 15 @ 11:25 pm
