Forum: Beta Builds Regression Bugs
Topic: BUILD 2520 - Page: 2
grfoto wrote :
version 2465 everything was ok, new versions have cue problem. use rightclick = "left deck set_cue 1 & cue_name 1", and the cue button always gets the selected color, unload the song, the selected cues does not disappear, even if you load another music, not disappears
Basically your command is wrong. It should be deck left set_cue 1 & cue_name 1
Also you should control the led independently.
Process: VirtualDJ [1087]
Path: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Version: 8.0.0 (8.0.2500)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: VirtualDJ [1087]
User ID: 501
Date/Time: 2015-10-21 01:10:19.620 +0200
OS Version: Mac OS X 10.11 (15A284)
Report Version: 11
Anonymous UUID: ECDC6733-BAEB-FAC5-10A0-CC47EB58F6AA
Time Awake Since Boot: 1000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000020
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x20:
__TEXT 000000010784d000-000000010913d000 [ 24.9M] r-x/rwx SM=COW /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.atomixproductions.virtualdj 0x0000000107916331 0x10784d000 + 824113
1 com.atomixproductions.virtualdj 0x00000001079c8758 0x10784d000 + 1554264
2 com.atomixproductions.virtualdj 0x000000010794b6e7 0x10784d000 + 1042151
3 com.atomixproductions.virtualdj 0x0000000107c0333e 0x10784d000 + 3892030
4 com.atomixproductions.virtualdj 0x0000000107e74e2f 0x10784d000 + 6454831
5 com.atomixproductions.virtualdj 0x000000010794b5e4 0x10784d000 + 1041892
6 com.atomixproductions.virtualdj 0x000000010784e974 0x10784d000 + 6516
only answer if you test.
exactly this is the command: deck left set_cue 1 & cue_name 1 ,
translated by google, sorry.
I tested and it works fine.
Also as I said, you should control the led independently
music234 wrote :
Workaround:
download b2483 from my account
save settings
install b2483
install update to 2520
restore settings
...and everything is fine ;o)
for me too... i had installed new El capitain, then i click in the skin on a button and see the crash and canĀ“t open virtual dj again.
I backup my settings, download the released version on my mac and restore my old settings...
After open new installed Virtualdj, the programm make a update to the new beta...
i think and hope everything is fine, now.
