Forum: Beta Builds Regression Bugs
Topic: BUILD 2500 - Page: 2
Localization of default skin find a serious error,
After some fields translation,Unable to display other language translation;
For example:
I don't understand what you mean exactly.
If you have a translation xml that is broken, could you send it to me?
(Also, it is recommended to remove the update="" fields from the xml after updating the translation, that way it will be much easier to update the translation in a next version, since only the items that require an update will have a new update="" field)
My friend Adion,I translated it again,Everything is all right,I don't know where is the problem.
I feel...After translation, only show two words,And very small.On the low resolution does not make sense.
But in terms of language localization,this is a very good job.
There have been a few other products do well in Chinese,Including the official website,I have been working to promote the VirtualDJ.
1920x1080
Can you send the updated translation? It looks good, although some words indeed look very small.
Full unexpectedly close while working ...
Details?
system completely frozen (video& audio), because lost sound card (controller)
after re-pressing "Apply" all operate normally
system w7/64bit
vestax vci 380
Braenzu
The sound effects on deck stop working until I close virtual dj and open again, then happened again last night, also I still cant figure why I can only see the color text tags in the browser and remove samplers only if I run vdj as an administrator to open it.
You can't. If you are online while the crash happens the crash report is submitted automatically.
Also, the screenshot in that topic looks like it's a lock-up, not a crash, so unfortunately there would not be a report anyway.
if it was an accident ...... you can not capture the closure warning sign program
that precious must crash report on options virtual dj ??
my options
It is correct???
Pin a Effect on the window and can't turn on or off from @ the pin window and can't remove it also need to close VDj-8 to remove it.
OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
