I am now using a MAC and having a difficult time trying to download sound effects??HELP!!!
Eric
Eric
Posted Fri 09 Oct 15 @ 3:36 am
after you DL the Effect from you DL folder just hit open and it will install on it own.( 8 ) if your using VDJ-7 open move to VDJ- folder Plugin ( sound,video,visual )
Posted Tue 13 Oct 15 @ 2:06 pm
tell me how i can found sound effect in virtual dj 2020 and give me link
Posted Mon 06 Apr 20 @ 10:45 pm
Its right inside the software .. In settings, look for the Extensions tab :)
https://www.virtualdj.com/wiki/how%20to%20install%20plugins%20and%20addons.html
Posted Mon 06 Apr 20 @ 11:05 pm
I need sound effects of virtual dj 2020
Posted Sat 06 Jun 20 @ 4:09 pm
If you care to read the post immediately above yours....
Posted Sat 06 Jun 20 @ 4:47 pm
