Forum: Old versions
Topic: Directx error message - Page: 1
Hi
I am running virtual dj 8 on windows 10 OS. When i tried to launch the application I received this error message "Directx fail to initialize. Please install the correct drivers for your video card". I checked and rechecked all my settings even reinstall the application. I need your help in trying to solve this problem. The directx version is 12.
Posted Sun 04 Oct 15 @ 10:32 pm
AdionPRO InfinityCTOMember since 2006
It is more likely that you need to update your video card drivers.
Check your computer manufacturer's website for drivers for your computer, or alternatively check intel, nvidia or amd websites for the most recent drivers for your video card.
Posted Mon 05 Oct 15 @ 4:08 am
pegeasHome userMember since 2016
I have the same problem. you could solve ?
Posted Thu 18 Feb 16 @ 7:59 pm
RobRoyPRO InfinitySenior staffMember since 2012
regarding to your issue, troubleshooting is already posted above.
As Adion mentioned, please check or update your Videocard drivers
and assure you have installed the required directX9 packages
Posted Fri 19 Feb 16 @ 7:04 am
Posted Fri 19 Feb 16 @ 7:29 pm
YES THIS IS SO FRUSTRATING I HAVE UNINSTALLED VIRTUAL DJ 8 THEN REINSTALLED, UPDATED THE VIDEO DRIVERS, CHANGED TO THE INTERNAL DRIVER WITHIN MY LAPTOP, UPDATED WINDOWS 10, AND DIRECTX IS STILL STOPPING ME FROM OPENING VIRTUAL DJ 8 THERE IS OBVIOUSLY A GLITCH IN THE PROGRAM. I AM A NATIONAL AWARD WINNING DJ/ VJ AND I AM REALLY GETTING FRUSTRATED WITH THE WHOLE THING. I HAVE VERY IMPORTANT GIGS WITH DOUBLE PROJECTION SCREENS THIS WEEKEND AND I HAVE NO FUNCTIONAL DJ SOFTWARE DUE TO VIRTUAL DJ !!!!!! PLEASE HELP ASAP
Posted Mon 25 Jul 16 @ 2:32 pm
Looks like your caps lock button is stuck as well .......
You need to give more info. What you have provided isn't enough to diagnose the issue you are having. What exactly is the issue, what have you tried to resolve it, what steps have you taken, PC model, graphics card, OS, etc would be a start.
Posted Mon 25 Jul 16 @ 2:36 pm
Thank you for your reply.
Well the problem is quite clear:
DirectX Will not initialise.
So Virutal DJ will not load.
I have Nvidia GForce 720m
Asus Core i7
8GB memory
USB 3
My old Virutal DJ program worked fine.
Posted Mon 25 Jul 16 @ 2:43 pm
Which old virtual DJ program?
Which operating system are you currently using?
Posted Mon 25 Jul 16 @ 3:03 pm
windows 10
Posted Mon 25 Jul 16 @ 3:04 pm
My old Virtual DJ Software was Called Virtual DJ Full Professional.
Posted Mon 25 Jul 16 @ 3:11 pm
he meant what VERSION of "Virtual DJ Full Professional" you are using.
Posted Mon 25 Jul 16 @ 6:01 pm
Anyway, you might need to install Directx 9.0c
Posted Mon 25 Jul 16 @ 8:00 pm
taylaPRO InfinityMember since 2007
Posted Mon 25 Jul 16 @ 8:48 pm
I HAVE INSTALLED VIRTUAL DJ 8 IN MY PC I HAVE WIN 7 32 BIT AND IT IS SHOWING ME DIRECTX FAILED PLEASE CORRECT THE DRIVER OF YOUR VIDEO CARD
Posted Fri 02 Dec 16 @ 3:27 pm
Well read the page, follow the links and update your drivers, if you still have problems come back and report them.
Posted Fri 02 Dec 16 @ 4:23 pm
Would love to install VDJ 8, But my system has a more robust and efficient way of running Virtual DJ 7 and Traktor Pro 2.11 without Graphics Drivers. Honestly, is it possible to run VDJ 8 without them also?
Posted Fri 23 Jun 17 @ 4:47 am
If your graphics driver wasn't running, you wouldn't see anything. You'd have a blank screen.
Your computer operating system needs a graphics driver in order to display things on the screen.
Posted Fri 23 Jun 17 @ 9:33 pm
supadaHome userMember since 2017
Thanks for the good information and articles.
Posted Wed 28 Jun 17 @ 5:03 am
95%
