Topic: scan bpm problem
SKOSTPRO InfinityMember since 2013
Recently change my hd to fat32 for better performance on Mac. When i select songs to batch & analyze for bpm... run the analyze for a few songs and then froze and always shows the infos of the song frozen (such as Free your....(0%)) and need to restart VDJ to unblock.
Looking for a solution. Thank you
Posted Fri 18 Sep 15 @ 7:34 am
Does it always hang on the same song ?
If so, please upload a file that makes BPM scan to hang on a server and send us the link to check it.
Posted Fri 18 Sep 15 @ 9:34 am
Same Problem here!
Posted Fri 18 Sep 15 @ 12:29 pm
its not always hang on the same song. The problem happened at any song
It always fail to scan over 10 songs.
I tryied many times and always had to restart Vdj !!!!
Posted Fri 18 Sep 15 @ 8:42 pm
Hello, is there any new infiormation about that bug?
Posted Tue 22 Sep 15 @ 11:10 am
Did you upload one of the songs it hangs on and send a ticket to the support team as asked above?
Posted Tue 22 Sep 15 @ 12:21 pm
Same problem here. Never the same song, if I restart it goes well. I think it's when I want to scan more directory's.
My MBP now also scans 1 song, where I think on previous builds it was 3 songs.
Posted Tue 22 Sep 15 @ 2:29 pm
i upload 2 pics and a song
wait for an answer...
Posted Tue 22 Sep 15 @ 4:59 pm
i have problen even in one folder see pics
Posted Tue 22 Sep 15 @ 5:02 pm
freeze at 58% (comand+alt pic)
Posted Tue 22 Sep 15 @ 5:05 pm
correct pic
Posted Tue 22 Sep 15 @ 5:06 pm
jyouncePRO InfinityMember since 2015
Have submitted a ticket as well. They asked for me to update to latest version - i did. Still same issue. Random songs. Random amount of songs analyzed. Doesn't matter file type or anything. Very annoying. I have several new songs I need to analyze and cannot.
Posted Fri 02 Oct 15 @ 11:59 pm
There was a fix for a possible analyzing bug.
Please try again with the latest beta build 2479.
Posted Mon 05 Oct 15 @ 9:14 am
FYI - looks like the latest beta build fixes the issue (knocking on wood!!) :) :)
Posted Tue 06 Oct 15 @ 1:21 am
There was a fix with the latest beta build 2479.
Thank you all
Posted Thu 08 Oct 15 @ 7:09 pm
