Forum: Old versions
Topic: My controller doesn't work
Hi,
A long time ago i bought a dj console mk4 and used it on my old Macbook, now i bought a new macbook but still got the old controller.
My new mac doesn't have a cd reader so i downloaded everything from the virtual dj site. Now the problem is my controller works only for 10 min. And it says that i should buy a license, but i still got one for that console, how can i make it work for longer then 10 min without buying a new license?
thanks,
greets Tris.
Posted Thu 17 Sep 15 @ 2:53 pm
I assume you still have the serial/keygen of the Limited/Console Edition of VirtualDJ 7.
If so, use this link to download the installation file... https://virtualdj.com/le
Not sure though if this old version will work on the new OS.
To use VirtualDJ8, you will indeed need to buy a license.
why would he need a new liscence if he has VD pro? I have both VD 7 and VD 8 pro installed on my laptop, it is tight now, being migrated at the apple store to a new laptop, will i not be able to use these on my new one (and with my traktor s4 mk2 and y denon 6000 (1st version)??!!
Do you see or read anything i missed from his post that makes you think that he has a VirtualDJ Pro License ??
