Forum: Old versions
Topic: Microphone LOW Volume
Hi Everyone, I wonder if you could help me.
I use VDJ7 with a Reloop Controller. My VDJ Settings are set to Input: Microphone, Output: Headphones, Sound card: Built In.
I plug a Microphone into my controller and adjust the volume to its maximum on the dial but the master output of the microphone is so low and I can't increase it in anyway... What am I doing wrong? lol.
Posted Wed 09 Sep 15 @ 7:54 pm
Which Reloop controller?
Usually, setting VDJ to Input: Microphone uses the mic input on the computer - not your controller.
When you plug a mic into your controller, the signal will be sent to the output of the controller - not VDJ.
The concept to grasp is that the audio signal goes out from VDJ to your controller. If you plug a mic into the controller (after the sound has left VDJ) then the signal will be output from the controller. You should also be setting the VDJ output to 'master/headphones' and using the controller's audio interface.
