Hi
I have VDJ8 loaded on my MacPro with an N4 controller connected via USB port.
There is no audio output to the Controller. So no audio to controller, amp, speakers or headphones. Apart from an annoying "click:
Audio settings are set to N4 Audiocard. And the Sound settings in the Mac can see the N4 device, but reads "THIS DEVICE HAS NO AUDIO OUTPUT
Appreciate any help...
Thank you
Onofrio
Thank you
Onofrio
Posted Mon 07 Sep 15 @ 7:48 pm
well, if your Mac provides that message, VirtualDJ will not be able to output any sound of course, since the OS doesnt report any Outputs.
Try to plug to a different USB port, or check in Audio Midi Setup in case you have changed/set anything incorrectly there.
Posted Tue 08 Sep 15 @ 9:29 pm
Thanks for your help. Already tried audio midi set up and different ports.
I'm going to try a different laptop. Maybe a windows pc.l? That way I can isolate the issue? Hopefully ! ;-)
Posted Tue 08 Sep 15 @ 11:06 pm
