-Fix delay between sound and waveform after seeking in mastertempo quality 2 (#2425 regression)
-Fix green on some videos with dxva
-Fix possible analyzer crash
-Fix unable to rename virtual folder with no files in it
-Fix custom context menu crash
-Fix detailed waveform colors slightly off and possible crash
-Fix possible crash in sync action
-Fix possible crash in Camera plugin
-Fix video getting stuck in some cases when using loop roll with video enabled
-Fix autogain not applied sometimes when using load & play in a single action
-Fix action auto-complete preferring synonyms
-Track Cleaner now correctly shows and prelistens modifications
-Some performance optimizations
Posted Sun 30 Aug 15 @ 11:31 pm
Nice! Can't wait to start testing!
Posted Mon 31 Aug 15 @ 12:02 am
- Fix unable to rename virtual folder with no files in it
Failed fix. I haven't tested on PC yet, however testing on a Mac with this build still fails.
Video of failed fix:
http://www.hv1.net/vdj/vdjbug.mov
Posted Mon 31 Aug 15 @ 2:14 am
Works on PC (Win7)
Posted Mon 31 Aug 15 @ 2:35 am
This update appeared just after I finished my dj set in balham, I can confirm the following
Sorted!
Performance improvements
Start up and close was about 8 - 10 seconds, now its about a second.
Waveform and sync
Yup, now works as it should, will test other things tomorrow
Sorted!
Waveform and sync
Posted Mon 31 Aug 15 @ 2:51 am
***Regression Bug on this build.
Used video editor to to create a vdjedit file. Once i press save the vdjedit file can't be found on the virtual dj search but the file is created in the windows explorer and if a drag and drop it on the deck it will play fine. Tried "add to search db" and the file won't come up on the search no matter what. Using windows 7 64 bit
Posted Mon 31 Aug 15 @ 4:54 am
Seems to show up fine here. Is autoSearchDB in options set to no by any chance?
Posted Mon 31 Aug 15 @ 9:30 am
Confirmed fix on PC (under Windows 8 and Windows 10), however still a failed fix on Mac.
Posted Mon 31 Aug 15 @ 2:17 pm
Updated version of the MultiFX skin. Introduces the "Rack Panel" system. Video Support. ArtCover on deck or jogwheel (djdad), video does not work, turning, vdj close completely ...
![](/image/62598/169548/image.png)
Posted Mon 31 Aug 15 @ 2:33 pm
hi this version has a defect that when looking at the list of songs in the browser waves are blocked
Posted Mon 31 Aug 15 @ 3:51 pm
Could you elaborate please, I didn't understand what you meant.
Posted Mon 31 Aug 15 @ 3:56 pm
I have it no because i want to manually add my songs on the search. But usually when i create a new vdj edit file with the video editor it shows up on the search. But that is not the point here. Even if i manually add the folder containing that file it will not show up in the search. I will try to use another video file to make sure and comeback with feedback or a video. In the meantime i will unistall vdj 8 and install it again as i see that sometimes this resolves issues like this.
Posted Mon 31 Aug 15 @ 4:16 pm
Adion looks ok now. Yesterday i couldn't make a file to show up on the search no matter what i did! I uninstalled and installed (tried to see that it works with the public build it worked) and then i updated tried again with this beta and it worked. It even made it show up automatically on the search even if i have the auto option off. You can scratch this one off.
Posted Mon 31 Aug 15 @ 4:26 pm
This beta were supposed to fix some green video bug that never occurred before to me, but now I have this bug on this new beta version.
Posted Mon 31 Aug 15 @ 10:53 pm
This problem is still here. Adion its doing it again with the same video clip i have uploaded on the bug section.
Posted Mon 31 Aug 15 @ 11:35 pm
And it still happens when I reinstall the last stable version
Posted Tue 01 Sep 15 @ 12:07 am
Details might be good, Win? Mac?...
Posted Tue 01 Sep 15 @ 2:04 am
Windows 10, sorry xD
Posted Tue 01 Sep 15 @ 11:58 am
windows 7 as well
Posted Tue 01 Sep 15 @ 2:00 pm
On another windows 10 pc I have it didn't happen, only on my working laptop.
Posted Tue 01 Sep 15 @ 5:56 pm
