Forum: Old versions
Topic: Numark Mixtrack Edge and Virtual DJ 8
I'm new at DJ controller and Virtual DJ 8.
I want to know how can I stop a track on Virtual DJ 8 using Mixtrack Edge?
It only has buttons for play/pause and cue and no stop button.
Posted Sat 20 Jun 15 @ 12:18 am
Pressing CUE button while music is playing, will stop the track, and will return to the last "saved" position (also called "cue")
Pressing PLAY button while music is playing, will also stop the track at the current position (pause)
Yes it does but I want to totally stop the track and go to the beginning of the track.
The same way the stop button does on the screen of VDJ 8.
If your controller does not have a dedicated "stop" button then you need to modify one of the existing buttons ta act as stop.
The code you need to use on the button on controllers page is "stop" (without the quotes)
Thank you. I will try that.
