Forum: Addons
Topic: Remote DualDeck Control
Posted Mon 15 Jun 15 @ 3:27 am
Very tidy.
Posted Mon 15 Jun 15 @ 5:30 am
Ok, is this the replacement for the old one? Do we as pro users have to buy this? The last ones reviews were horrific.
Posted Wed 17 Jun 15 @ 12:01 am
No, this is a skin. The VDJ remote is an app. If you bought the app then the upgrade to the new one should be automatic (and free).
Just be aware that the new app won't run on 1st gen iPads as claimed.
If you do install it (it lets you do so) it overwrites the old one, and apparently there's no way back. I would've thought that you could reinstall from a backup of the old version...
Posted Mon 13 Jul 15 @ 10:23 am
sliser, loop roll, custom pads are NOT worked! :(
Posted Fri 30 Sep 16 @ 12:20 pm
hi...
i like your skin !!!
but can you fit the screen to the resolution of my iPhone 6+ PLEASE?!?
THX4 & good work for you...
best regards from a german home dj
Posted Sat 04 Feb 17 @ 2:03 pm
hrdnxPRO InfinityMember since 2011
Android????????
Posted Sat 04 Feb 17 @ 3:23 pm
I managed to wrongly set the custom buttons before I realised there was no play button on the skin. Is there any way to reset them. I tried by reinstalling after deleting the remote skin but it just keeps coming back with the buttons already assigned.
Posted Thu 27 Dec 18 @ 9:18 pm
