Forum: Old versions
Topic: CDJ 400 with VDJ 7 Pro
Hello,
I have two CDj-400, external mixer and VDJ 7. I have downloaden the newest firmware from pioneer. So i can you most of the key on my CDJ.
When i you no software with the CDJ the nice thing about the CDJ 400 is that i can fine tune the loop. I press the loop out button and with the forward of back key of jogwheel i can make the loop longer of shorter.
If i use VDJ i can not use this option. Or i don't know how?
On other nice future is that when i press Loop out, automaticaly form that point a 4 beat loop is made. That olso works if i don't use software...
Does some one has a tip of I see that there is a key learning future but i can't manage it
Thanks!
Posted Tue 09 Jun 15 @ 2:37 pm
And if i buy a month for 19 dollar...can i download everything that i think i need... or do you need a full license ?
The $19/month option gives you access to everything for V8 but nothing for V7
V7 has a dial in the loop section that moves the loop exit point forward or backward, I think everything you need is possible.
It may be probably better to try Nederlandstalig forum as there are some very knowledgeable users who speak Dutch.
https://virtualdj.com/forums/9/Dutch_Forum.html
thxs...i will go to the dutch forum :-)
