Ok so now that we have a new version and it works great can someone please make a skin that looks exactly like a Pioneer DDJ SP1??
No wave, no track titles, a button for the library.
Just like this,
If someone could do this I'd be greatful 🙏
Just like this,
Posted Sun 07 Jun 15 @ 12:20 pm
I was thinking of making something like this, when i was creating the ControlDeck i submitted a few days ago. Will have something in about 2 weeks (hopefully)
Posted Mon 08 Jun 15 @ 2:17 pm
Can you just harvest the pads of SS2?
Posted Mon 08 Jun 15 @ 2:45 pm
Sounds good Bob!! Can't wait to see what you and Phantom come up with 👍
Posted Mon 08 Jun 15 @ 3:13 pm
Effects like the left or the right deck ?
dont say both, you re killing me lol
I suppose you dont need any Sync, Slip etc buttons, right ? Just the Pads and Effects.
Btw, the skin will offer Decks and Waves too on a different panel (replacing Effects)
Posted Tue 09 Jun 15 @ 11:54 pm
I'm gonna have to say the right is more appealing to me 😜
And yeah I don't need those but others may like to have them. Lookin good though and can't wait to give it a spin 👌
Posted Wed 10 Jun 15 @ 12:20 am
I say both ("you've killed me") with a button to swap between the parameter controllers?....awesome gismo Bob...
Posted Sat 13 Jun 15 @ 6:10 pm
What you see in the pic above is done already and sent to Huey. Will add a panel to offer decks info and waves and hopefully available within the next few days.
Posted Sun 14 Jun 15 @ 2:55 pm
Available
Remote DualDeck Control
Download Link
http://www.virtualdj.com/plugins/index.html?addonid=80267
Tips:
Options panels for Hotcues, Slicer and Sampler (tap the mode button again when mode is selected)
AutoLoop button panel cycles through 3 Loop size banks
Download Link
Tips:
Posted Mon 15 Jun 15 @ 3:28 am
Hmm there's a few buttons on this new one I see, gonna have to grab it and check it out........ Got a version without a wave??
Posted Mon 15 Jun 15 @ 12:17 pm
I can mail you a VirtualDJ sticker to put on top of the waves lmfao !
Kidding. check it out and i ll make something for u
Posted Mon 15 Jun 15 @ 5:18 pm
Pressing the slicer mode button twice gave me this result,
Some pretty good stuff going on with this skin!! Definitely will be hitting you up tonight 👍
Posted Mon 15 Jun 15 @ 6:16 pm
This skin and the one i sent you have some similar namings in panels, variables etc.
Unfortunately what you got may happen if you change skins, since all the skins share and use the same line in the settings.xml.
try to re-launch the Application and if there is still an issue, delete the line <skinPanels> from the settings.xml and relaunch.
Posted Mon 15 Jun 15 @ 6:52 pm
Just noticed this this morning,
I'm gonna assume this is the loop roll section?? Well mines gone 😳
Anything I should do to fix it or is this on your end??
Posted Tue 16 Jun 15 @ 7:06 am
read my previous reply. I hate quoting myself :)
Posted Tue 16 Jun 15 @ 5:20 pm
Ok I did what you said and now my loop roll section is showing up (it also doesn't show up in my videos so can this please be changed??) but the slicer view is still not showing up right.
But I have a few request, I went through and to screen shots of the views I'd like.
This is the only hot cue view I need, and please add a cue lock button??
This is the only sampler view I need,
And this is the only slicer view I need,
Could I please get one more custom button up top?? With these small changes the remote would be perfect in my opinion 😜
Or if these are easy things I could do myself I'll do it under your direction 🙏
Posted Tue 16 Jun 15 @ 9:41 pm
I wont change the skin i uploaded, but i could do a modification for you.
Posted Wed 17 Jun 15 @ 5:53 am
Yeah that's fine 👍
Thank you 🙏
Thank you 🙏
Posted Wed 17 Jun 15 @ 9:55 am
Hey bro, not sure if you have started it yet but I don't need the x/y pad either, lol!
If it's to late that's cool, I'm just glad you've taken the time to hook me up with this 🙏
Posted Thu 18 Jun 15 @ 11:26 am
not yet. Probably during weekend
Posted Thu 18 Jun 15 @ 2:00 pm
