Forum: Old versions
Topic: Update problem BUILD 2282
When i start virtual dj, the software says that my virtual dj is updated and asks me if i want to use the updated version.
Then i choose yes, i get the message from user account control (windows) i then agree but the update fails ?
My system is windows 7, AV is Norton Internet Security, VDj update: BUILD 2282
This system is rarely used and once in a while i use it in my hobby-room.
Posted Wed 03 Jun 15 @ 9:01 am
i disabled UserAccountControl, and now everything seems to work !!
Once again, the newest update didnt install.
Weird problem. Everytime i get a update, looks like it doesnt work.
It says, new version at startup (would you like to use it ?). INSTALL FAILED ?????
Disable Norton and try again.
