Forum: Old versions
Topic: dj2go v8 problems
recently upgraded from le to version 8. recognizes license on my page but i still get the buy to continue message after 10 mins. Have reinstalled le and plus on my machine.
Posted Wed 27 May 15 @ 8:04 am
Version 8 requires a login to access the features you are licensed for. If you have not logged in go to the config options, select LICENSES from the column on the left, under USER login with the same credentials you used to create your account with VirtualDJ.
I am logged in. My current license says ion dj 2 go whilst there is a prompt to upgrade with this controller = numark dj 2 go. this is the controller i regestered with and used the code from it to get a discount.
You might try opening a support ticket. https://virtualdj.com/contact/ this link will begin the process.
If we're lucky maybe someone knowledgeable will stroll by this thread and provide direction. Sorry I'm not more help.
