I have been using VDJ8 and for a video gig, I am wanting to use VDJ7. When I open it, my current virtural folders are missing. Is there a way to import or find them?
Thanks,
Thanks,
Posted Wed 13 May 15 @ 9:41 pm
There is no way to do that (on MAC) without heavy manual editing of vFolder and Database XML files.
EDIT:
Maybe try this, it might work...
For every virtual Folder of Version 8, create a playlist with the content of the vFolder.
Now, open V7 and go to the playlists folder in the browser. You should see the new created playlists.
Either use it like that or create new virtual Folders in v7 and drag&drop the content of the playlist into the vFolder.
EDIT:
Posted Fri 15 May 15 @ 3:59 am
