I'm trying to get the XDJ-RX controlling VDJ8 and need some basic help to get me started. (I have already had some great advice BTW from PhantomDeeJay, Jakovski and others; cheers guys)...
I'm creating the definition file as prescribed in VDJpedia and have got as far as setting up the device id, vid, pid etc but am stuck with defining the midi signals for each button/slider/jog element. I require the midi note or cc note but have no idea how to obtain it for each physical button.
Is this something which needs to be supplied from Pioneer as a list, or is there a utility or function within DDJ that can display this information? I have managed to find a hardware midi diagram for Tractor but this is not the same thing, and the ".tsi" file has no reference to midi codes..
Any help would be gratefully received :-)
Cheers, Rob
Cheers, Rob
Posted Wed 13 May 15 @ 4:27 am
Have you tried miditrace?
https://virtualdj.com/download/miditrace.exe
Posted Wed 13 May 15 @ 4:56 am
Thanks locodog...but JUST found this :-) Game on!!
http://site2.pioneerdj.com/support/files/img/XDJ-RX_List_of_MIDI_Message_E.pdf
Posted Wed 13 May 15 @ 5:10 am
Rob ? Can you send me a PM please ?
I may have done all the hard work for you allready ;)
Posted Wed 13 May 15 @ 5:52 am
