Whenever I go to use the automix editor in VDJ8, I notice a high CPU spike using the editor. Sometimes I see the spike just as the window is opened and at other times, it occurs when I use the slider to move down the list of queued up songs. Is there anything that can be done to minimize this? The laptop I'm using is a i7 core with 8gig memory.
Posted Fri 08 May 15 @ 11:48 am
Do you have the overClock option on, this should help.
Posted Sat 09 May 15 @ 5:38 am
My overclock is set to YES
Is this typical behavior where the cpu gets pegged in the red for a bit?
Joe.
Joe.
Posted Sat 09 May 15 @ 10:21 am
Does it actually cause audio drop outs? If it doesn't, why worry, I imagine drawing those waveforms is pretty processor intensive.
Posted Sat 09 May 15 @ 12:30 pm
Every now and then the system will lock up but things will still play and then it will come back .. I used to use my drum machine to play along when 8 first came out but after all of the upgrades from both VDJ8 and Maschine 2, if I go into editor I will loose audio. So I don't use my drum machine anymore.. And I'd like to again.
Joe
Joe
Posted Sat 09 May 15 @ 12:44 pm
