Forum: Beta Builds Regression Bugs
Topic: BUILD 2245 - Page: 2
"Tag m4a and flac"
You don't write or read all tag of tag editor in file .m4a or .flac like:
- remix
- Remixer
- Label
Is it possible to write and read these tag like for mp3 files for m4a and flac files
Hello,
I have the latest build. I am listening to tracks via the pre listen tab with only the internal PC sound card. When I right click and delete a track the next track below is highlighted. I play that track in the pre listen window and the software reboots. I try to play the same track in the pre listen window after the software reboots and nothing happens. I check the sound card settings and internal card isn't selected so I select and still no sound. I reboot the software, select internal sound card and it works again. I've tried this twice with same results.
A few people mentioned crashes in the pre-listen area. I would suspect they will be addressed in the next release.
Yes, this bug (specifically deleting or moving files that have been played in prelisten and using prelisten again after) will be fixed in the next update.
Braenzu wrote :
I think i heard tempo fluctuations with this build in the songs
Braenzu
I have heard this on several occasions. Like the music 'warbles' in pitch, but not tempo. Kinda like the old days of 'wow & flutter'. Yes, I have many VBR files but all new tracks are CBR.
Has anyone else heard this?
This build, no but other builds, yes. Quite odd to hear it.
milkdrop to activate and switch effect , produces brake on skin ...
ewitles wrote :
Braenzu
that's what I meant, sorry
Braenzu
Value of "pitchQuality" in VDJ ?
2
Braenzu
