Sorted ;)
Posted Fri 15 May 15 @ 8:47 am
I've run into another "problem" that doesn't feel quite right.
As I understand, global slip is meant as a on | off (it has the highest control), the only thing that should switch it off is the command "slip off" but have found "loop 0" doesn't so much switch global slip off more resets it, I could find use for this somewhere else but it doesn't fit what I'm doing now and current behaviour doesn't feel like it was the intention.
I'm perfectly willing to be corrected.
Posted Sat 06 Jun 15 @ 6:10 am
Switched to slip_mode as opposed to global slip. It still feels like global slip isn't quite right.
Posted Sun 07 Jun 15 @ 4:50 pm
no highjack intended Loco but,filter roll works good.is this going to to be implemented in vdj? I mean can we implemented on the Numark NV's filer roll contrll knob? (check you pm's hombre) ;)
Posted Thu 11 Jun 15 @ 7:17 pm
Nuthin in inbox. was waiting for feedback, I'm thinking about changing the 0|100% action but something should be submitted before the month end.
Posted Thu 11 Jun 15 @ 8:14 pm
