hi I am using a denon hc dn-hc5000 everything is work ok apart from I cant get any sound out of my mixer can anyone help please many thanks
Posted Sat 04 Apr 15 @ 2:36 am
....and your mixer is?
Do you have the output of the mixer connected to audio equipment (amplifier and speakers or powered speakers)?
How is your HC5000 connected to the mixer?
What is your VDJ audio config setup?
Please provide as much detail as possible and be very specific. Remember, no one here can see your setup.
Posted Sat 04 Apr 15 @ 4:51 am
Hi ,
I have the same problems vdj works fine with denon dn-hc5000. soundcard extern and the denon is connected with cinch cabel like usual.
The sound works fine with serato itch, but thats not a solution because i bought vdj pro to use it with the denon.
Thanks for your help
Posted Fri 26 Feb 16 @ 3:57 pm
Hello,
i have the same problem, no sound via virtual dj 8 pro, Same installation and perfect sound in itch.
what can i do ?
greets
steve (Belgium)
what can i do ?
greets
steve (Belgium)
Posted Sun 16 Jul 17 @ 4:49 pm
