Forum: Old versions
Topic: High -Low Tones and Master changing by itself
Everytime i connect my middicontroller, the high and low tones changes by itself. Also the master drops more than 50%. I cant find the problem. Anybody?
Posted Fri 20 Mar 15 @ 3:39 pm
What build are you using?
If a MIDI controller is connected and the controller sends the positions of the faders on initialization, then the software will read those values and will adjust the software values accordingly. Its normal. I suppose you want to have "instant" control of the software mixer with yoru hardware, right ?
If sound drops at 50%, then maybe the controller has a Master Volume knob which at that point is at 50%, or maybe the Volume faders are in mid position
there is also a chance that the ONINIT of the controller you re plugging is having an action to reduce Master Volume ??
If there is still an issue, it would help to mention which controller you are using.
