Topic: sync LED blink
Hi , I need help to map my "sync" button LED to blink only when the tracks aren't synced, if they have the same BPM the LED could be off, is this possible?
thank you
( at the moment I'm using the script "loaded ? pitch_zero ? blink : off" )
Posted Fri 27 Feb 15 @ 9:18 am
SBDJPRO Infinity Member since 2006
This will only flash when the BPMs are the same:
get_bpm_match & param_equal 0.5 ? off : blink
Posted Fri 27 Feb 15 @ 9:23 am
thats great!just inverted the answers, so it blinks when off sync,
thank you
Posted Fri 27 Feb 15 @ 1:56 pm
