and I've just looked again, after work style, in the forum it tells me that there is a new post"it's blue!" but when i hit it it's my old post!
are you hiding something? or am I just an old fart?
Posted Tue 03 Mar 15 @ 4:36 pm
The post count is correct, so there is nothing hidden. Maybe someone edited their post.
Posted Tue 03 Mar 15 @ 5:20 pm
vertical , blue and green lines , right wing 3/4 videos ...
Posted Wed 04 Mar 15 @ 1:54 pm
just tried the browser colour... nice, i like it.
iv tried a couple colours, teal and Turquoise and nothing happened.
iv also tried red and blue and OK
is there a certain colour chart we should use
Posted Thu 05 Mar 15 @ 11:22 am
You used the names, or hex codes? I suspect the names are quite limited. You could say "blue" but not "duck egg blue" for example. :-)
Posted Thu 05 Mar 15 @ 11:32 am
i used the names... Im going to try the hex codes now that you mentioned it
Posted Thu 05 Mar 15 @ 11:34 am
on the ball GROOVEY
link to the HEX code im using
http://www.w3schools.com/html/html_colornames.asp
Posted Thu 05 Mar 15 @ 11:36 am
can the buttons turn to the colour we choose
please
please
Posted Thu 05 Mar 15 @ 12:02 pm
Which buttons?
It would be easy to make a row of buttons with fixed colours, that you would use to make the tracks those same colours.
It would not be so easy to have the colour of the buttons change to match the code you enter, because it needs to be written in the skin.
Maybe we need a button_color action, so it would be browsed_file_color #123456 & button_color #123456 :-)
Posted Thu 05 Mar 15 @ 12:19 pm
VirtualDj supports only the 16 basic color by name. All the others can be called via hex or RGB
browsed_file_color '#be33ff'
browsed_file_color '125,17,255'
Posted Thu 05 Mar 15 @ 12:44 pm
thanks phantom... what are the colours for the colours by name?
the buttons for the colour browser... just a thought
the image iv posted, see how it says browse... can we edit that to say blue, green red etc...
Posted Thu 05 Mar 15 @ 8:17 pm
Well they not HTML 3.2 colours, so far
Red, Orange, Yellow, Cyan, Magenta, Green, Blue, Black, White
7 to discover
7 to discover
Posted Thu 05 Mar 15 @ 8:42 pm
i fixed it... didnt see the chat box on the bottom to name the button
thank you VDJ 8 team for this
+10
+10
Posted Thu 05 Mar 15 @ 8:52 pm
The available pre-defined colors (used by their names) are available here.. https://virtualdj.com/wiki/ControllerDefinitionMIDIv8.html (scroll down to the RGB Multi-color Leds part)
Posted Fri 06 Mar 15 @ 1:44 am
Next build please.It has been almost two weeks since the last build.
Posted Sat 07 Mar 15 @ 7:27 pm
The team will take however long it takes to release a stable build. I don't mind the delay... First rule of development never ask for ETA or rush DEVS
Posted Sun 08 Mar 15 @ 12:06 pm
Please keep this topic for discussion of regression bugs, not for the discussion of when the next beta will be.
Posted Sun 08 Mar 15 @ 12:07 pm
