Hi, can you help me with this easy VDJscript skin code, please?
I want switch the colorplayed value in the songpos definition by $songpost variable. Simple action:
If $songpost = 0 .... <songpos class="songpos" colorPlayed="#222222">
If $songpost = 1 .... <songpos class="songpos" colorPlayed="#00a5e4'">
Just tested:
<songpos class="songpos" var '$songpost' 0 ? colorPlayed="#222222" : colorPlayed="#00a5e4">
<songpos class="songpos" action="var '$songpost' 0 ? colorPlayed='#222222' : colorPlayed='#00a5e4'">
<songpos class="songpos" colorPlayed="var '$songpost' 0 ? constant '#222222' : constant '#00a5e4'">
and other similiar variations, but It's not working. :-)
btw. is there any way, how I can disable progress bar in the colored songpos waveforms? I want show only this waveforms without any colored shadows for played parts.
Just tested:
Posted Wed 18 Feb 15 @ 10:59 am
I think maybe you need to state visibility instead.
One colour with visibility=$songpost 0 and the other colour with visibility=$songpost 1
Posted Wed 18 Feb 15 @ 11:34 am
<songpos class="songpos" colorPlayed="#222222" visibility="var '$songpost' 0">
<songpos class="songpos" colorPlayed="#00a5e4" visibility="var '$songpost' 1">
Posted Wed 18 Feb 15 @ 11:36 am
Yes, now It's working, thanks.. :-)
And my next question, how I must change this definition,
<define class="songpos" classdeck="1" colorPlayed="#222222" colorBass="#00567a" colorMed="#00a5e4" colorHigh="#7fc8e9" >
if I want the same colors without shadows for played and unplayed parts of the song? I have green progress bar under the songpos window:
Posted Wed 18 Feb 15 @ 12:07 pm
You can use colorplayed="transparent" or colorplayed="#000000" but you will still get a "darker" shade on the played part of the waveform
Posted Wed 18 Feb 15 @ 3:17 pm
