Topic: VST Effects & VDJ8? - Page: 1
Rnow3PRO InfinityMember since 2011
Any recommendations on some good VST effects that are compatiable with VDJ8 free or paid
Posted Tue 10 Feb 15 @ 1:32 am
Paid for:
Turnado (more awesome than a monkey in a tuxedo made out of bacon)
Effectrix (sequenced multiFX)
For free:
Loudmax (A must)
TAL Filter 2 (mousey but the best drawn line filter anywhere)
TAL Flanger (TAL rule)
DVS Neon Gate (A pretty clean and effective gate)
Bionic Supa delay (the best single effect VST I've seen)
SupaTrigga (random re-arranging mashupness)
Bouncer (KVR challenge 07 entry, trippy druggy disappearing down the plug hole)
Posted Tue 10 Feb 15 @ 7:59 am
Posted Tue 10 Feb 15 @ 9:51 am
krn3kiPRO InfinityMember since 2014
Locodog, where's the point in Loudmax if VirtualDJ 8 already has it's own limiter? What does it improve?
How do you even map VST like Bionic Supa delay?
Posted Sun 12 Apr 15 @ 7:12 pm
Loudmax, try it, then ask questions, if you have any.
Bionic supa delay, map it just like any other VST, use a VST host to get the numbers for the dials
Posted Sun 12 Apr 15 @ 8:00 pm
espepePRO InfinityMember since 2009
This effects works only in windows?
Posted Mon 13 Apr 15 @ 12:23 am
I dunno, I've only got a windows machine, don't macs us Audio Units?
Posted Mon 13 Apr 15 @ 12:38 am
looking for anyone using a dubstep working vst... I need to learn this to mash.
Posted Tue 25 Aug 15 @ 6:28 pm
nxgn1PRO InfinityMember since 2005
Whats the best setting for LoudMax please.
Thanks in advance
Posted Sat 20 Aug 16 @ 5:16 am
I have it ONINIT on master with the dials at 90% 100% but it's up to you and your ears to figure what works best for you
Posted Sat 20 Aug 16 @ 10:56 am
What is that like -3 and 0 ?
Posted Sat 20 Aug 16 @ 1:28 pm
Yeah sumat like that.
Posted Sat 20 Aug 16 @ 1:32 pm
SBDJPRO Infinity Member since 2006
Just a follow up to this (despite it being an old post) to confirm that VDJ8 Mac will use VST plugins too, as long as they are Mac versions obviously.
Posted Sat 20 Aug 16 @ 2:30 pm
Got any examples??
Everytime I try to install one on my Mac (yes the Mac version) I get the"this plugin is not compatible" message.
Posted Sat 20 Aug 16 @ 5:50 pm
If you want to set LoudMax to activate every time at startup, in the controller settings in Virtual DJ8, in the Keyboard mapper,
type ONINIT. Then type the string:
deck 1 effect "loudmax" active & deck 2 effect "loudmax" active & deck 3 effect "loudmax" active & deck 4 effect "loudmax" active
My settings are:
Threash -9db
Output -1db
This works with and without my controller. It's a great tool.
Posted Fri 26 Aug 16 @ 1:14 am
lincol2PRO InfinityMember since 2011
As the "Threash" slides to the left you hear that increase volume. So instead of using the master volume knob to increase volume you move the "Tresh" slider on the loudmax? Is it the same result?
Posted Thu 01 Sep 16 @ 2:04 pm
Bad idea it you move it to far you will lose dynamic range and compress your music too much all it will cause listener fatigue
I would set thresh to a few points below average peak and other slider to -0.5
Posted Thu 01 Sep 16 @ 4:45 pm
Also I would recommend running it as a master fx instead of on each deck unless you have external mixer setup
Posted Thu 01 Sep 16 @ 4:48 pm
How do I get Glitch to work on a Mac???
Heres what Ive done,
Mac
After opening the ZIP in Finder, you should see the following items:
* Glitch2.component
* Glitch2.vst
* Glitch2_Presets
Copy the "Glitch2.component" file into the following location:
Macintosh HD > Library > Audio > Plug-Ins > Components
Copy the "Glitch2.vst" file into the following location:
Macintosh HD > Library > Audio > Plug-Ins > VST
Copy the entire "Glitch2_Presets" folder to a common location that can be
easily accessed, such as your Documents folder.
Yet nothing shows up in VDJ.
Posted Fri 02 Sep 16 @ 3:27 am
Glitch2 on pc was a none starter, (didn't load presets, only useful for random or on the fly arrangements.
effectrix (more or less the same) however worked ok
Posted Fri 02 Sep 16 @ 4:10 am
43%
