Just recently, my VDJ8 does not update my "comment field" in VDJ8. iTunes shows comments are there. Tracks in VDJ8 shows nothing or old data in the field. Will not update with current information. Help? Thanks!
Posted Sat 07 Feb 15 @ 9:52 am
there was a recent fix for that are you running latest build?
Posted Sat 07 Feb 15 @ 10:44 am
what version is the latest. I been clicking on all the updates when prompted?
Posted Sat 07 Feb 15 @ 11:37 am
I have Build 2144.933
Posted Sat 07 Feb 15 @ 11:39 am
That's the latest. Are you adding entirely new tracks to the database when this is happening, or trying to reimport data from existing ones?
Posted Sat 07 Feb 15 @ 11:45 am
just trying to update data in the comment field of tracks that already in my library. Some of the comments are correct and a lot are previous comments.
Posted Sat 07 Feb 15 @ 12:05 pm
VirtualDJ does not automatically reload tags, since that might overwrite some changes you made from within virtualdj but not saved to tag again.
To synchronize the vdj database, you would have to manually use 'reload tags'.
Posted Sat 07 Feb 15 @ 9:06 pm
